450D shift lever
Posted by Bill46 on February 27, 2007 at 05:03:07 from (65.200.157.177):
Working on the 450D and decided I want to fix the shift lever. Every once in awhile it gets stuck between 1st and reverse. Then I have to stop and pull the pin out, remove the lever and set the slide rails.
Is there anyone that makes a replacement? Can the lever be built up with a welder?
Tractor works ok, but the shift lever is a pain in the backside.
Thanks for your help.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
