Re: getting sleeves and pistons out of block
Posted by Tom Windsor on February 27, 2007 at 15:08:15 from (152.163.100.199):
In Reply to: getting sleeves and pistons out of block posted by HENRY E NC on February 27, 2007 at 14:27:41:
The crank is out? and the piston is in the hole stuck. You can either drive the sleeve and piston as a unit out as mentioned below or, before doing that, I would consider a solid piece of wood down in the sleeve onto the top of the piston with a "very big" hammer. I think with some very solid whacks it will break loose--and sometimes it does and sometimes it doesn"t and in either event, it is very aggrivating.
TW
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
