Re: getting sleeves and pistons out of block
Posted by John A. on February 27, 2007 at 21:09:46 from (65.150.79.34):
In Reply to: getting sleeves and pistons out of block posted by HENRY E NC on February 27, 2007 at 14:27:41:
Henry, Tomorrow clear the area of all combustable materials, Fill that cylinder with DSL then put in a splach of gas on top to ignite it with and let it burn itself out. Then take a hammer and block and drive it out. If that piston is more toward the top of the stroke so that there isn't much liquid holding capacity, you may need to repeat the burn process twice or so. The fire will expand the sleeve just enough to get that piston out. It can be save, if need be for future use. Then let the sleeve cool down and use your sleeve puller. Hope this helps.
Later,
John A.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
