Re: M W pistons
Posted by Lawmar on March 02, 2007 at 05:24:52 from (64.73.67.49):
In Reply to: M W pistons posted by 960 on March 01, 2007 at 20:55:01:
Experience - If you tear enough M farmall engines down you get to know what the different pistons look like. Same with heads. I bought a 400 Farmall and with simply taking one spark plug out I could tell it had IH Fire Crater Pistons in it and it had the 450 or 281 ci head on it. I came out good on that tractor. Of course none of this helps you. You will need to get a M&W piston and look at it and then take a look down your spark plug hole. You may want to buy a fiber optic viewer if your not sure what to look for. Or buy a head gasket and pull the head. Two people can have a head off in 20-30 minutes 40-60 if your slow. You oculd also have someone with some experience look down in there also. A viewer will also let you see ring groove and condition of the valves.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
