Re: Replace H axle gasket
Posted by Janicholson on March 02, 2007 at 09:39:57 from (199.17.6.122):
In Reply to: Re: Replace H axle gasket posted by john cub owner on March 01, 2007 at 20:14:41:
Another solution is to jack the Diferential just so there is no pressure on the axle housing, then remove all the bolts and (as you describe move it out a bit and clean all the gasket out. split a new gasket at the top and loop it into place with #2 permatex skimmed onto the gasket on both sides, and a little extra where they come together at the cut. JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
