Re: H steering worm gear
Posted by chuck46 on March 03, 2007 at 20:14:43 from (64.136.27.229):
In Reply to: H steering worm gear posted by Gary Puckett on March 03, 2007 at 18:06:13:
Hi, You can not turn the gear over because the spline it sets on is tapered, make sure the trust bearing and bushings on the upper bolster shaft are good, also the ball bearing and bushings on the steering shaft. Use a jack under the frame rails to check for vertical play on the bolster, use shim washers under the gear if you can. If this doesn't give you a good fit then look for another gear. Good luck, Chuck
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
