Re: H front end lube question?
Posted by Janicholson on March 04, 2007 at 08:21:57 from (66.216.226.55):
In Reply to: H front end lube question? posted by lekander883 on March 03, 2007 at 20:08:14:
I am confused. If behind is defined as being toward the seat of the tractor, not the radiator cap, then there are no gasketed components in the steering system behind the radiator. (unless it has some kind of non-stock power steering on it. The throttle control rod passes a center bearing with a universal joint (at the bulge in the hood) Ith has a fitting through a hole in the hood.
If the gasket is "in front" of the radiator, then that is the worm and sector gear box. Tough steering can be many things, including the bottom of the bolster thrust bearing (where the front wheels mount to the casting area with four bolts. Good luck, JimN
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
