Re: Not real on ebay?
Posted by farmallhal on March 04, 2007 at 13:47:29 from (64.85.221.207):
In Reply to: Re: Not real on ebay? posted by JIM MOSIER on March 04, 2007 at 09:07:51:
Jim, I'll jump in this for a couple of reasons. First, your tractor probably has a M&W 9 speed which adds an extra set of speed ranges to 1st through 4th. It also will increase the PTO speed to the same ratio since it is driven off the lower transmission countershaft. I'm not the 9 speed expert here but I think M&W was the manufacturer who had a cable control. I have a nine speed M which has a Heisler 9 speed which utilized a lever and rigid shaft to engage it in the transmission. It also has a belly pump disconnect to keep it from over running the belly pump. You would have the same problem with the belly pump on your tractor unless there is some sort of disconnect as the belly pump is run off the front end of the countershaft.
Second, I have never purchased anything from you but you had a Super C tractor a couple of years ago I wish I would have purchased. I discussed it on the phone with you in real detail and thought you were very forth coming with everything I had to discuss on the tractor. I later found out it was even better then you made it out to be in your listing and in our phone discussion. I always look at your for sale items both here on the forum and Ebay because I think you are among the better folks out there with trators and parts. It's just too bad an "ugly M tractor" got carried this far, Hal.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
