Re: International 460 Utility won't speed up
Posted by El Toro on March 04, 2007 at 15:03:33 from (64.12.116.71):
In Reply to: International 460 Utility won't speed up posted by Lyman on March 04, 2007 at 13:55:31:
Has it been working ok up until now? I would check that choke butterfly to see if its stuck closed. Make sure your throttle linkage at the
carburetor isn't loose. Try speeding up the engine at the carburetor by hand and see if it speeds up. It may be loose on the shaft. Hal
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
