Re: How do you clean a carburetor on a Farmall H?
Posted by Chad from Michigan on March 05, 2007 at 08:07:03 from (152.72.151.71):
In Reply to: Re: How do you clean a carburetor on a Farmall H? posted by flying belgian on March 05, 2007 at 08:03:15:
Well for starters it is hard to damage the carb. just be careful of the venturi is stuck just be careful when taking it out. Take the carb apart and soak it in carb cleaner. Take and make sure all the jets are clean and you can see through them. take and use air pressure and blow out the passage ways in the carb. IF you buy a carb kit follow the directions and re-set the float to the correct level. Its prety straigt forward so just take to your time.
Chad
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
