Re: What happened?
Posted by georgeky on March 05, 2007 at 09:06:37 from (152.163.100.199):
In Reply to: What happened? posted by Del Archer on March 05, 2007 at 07:15:19:
Del that is fairly easy to fix if it is the distibuter gear. Get you a IT shop manual and it will walk you through installing the distributer and timing it. Jump right in if your going to keep that thing you should try working on it yourself. It is not that hard and will save you a lot of money. It will also give you a great sense of accomplishment. Good Luck
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
