Farmall Tractors Discussion Board
Re: Re: M misses
Posted by Bob M on April 25, 1999 at 07:05:24:
In Reply to: Re: M misses posted by The Red. Been there done that on April 25, 1999 at 03:33:09:
The Red is probably right about valve lash. But before you pull off the rocker box and mess with the valves, check the distributor point gap (should be 0.020) and ign timing. Too small point gap and/or late timing can cause misfiring and flames in the exhaust - and it's easy to correct.
Post a Followup
: Re: Re: Re: M misses
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
