Re: Touch control question ?
Posted by gene bender on March 06, 2007 at 18:42:15 from (67.55.226.214):
In Reply to: Touch control question ? posted by Oddbob on March 06, 2007 at 18:09:07:
there are stops inder the hy rockshafts that mite be loose or not set correct. You mite need to move the levers back and forth several times to remove the air pockets in the hy fluid. Before you start it again remove the filler plug as there mite be pressure in the resivour. Be carefull removing the filler plug.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
