Farmall M bolster question
Posted by John S-B on March 06, 2007 at 18:50:03 from (205.188.116.133):
Ok, got the bolster out and I'm starting to clean it up. I noticed on the upper bolster, where the bushing is, there is a lot of wear. It's slightly rough and about as deep as the thickness of a pop can, maybe deeper. I have new bushings to put in but I'm wondering if I should just smooth the worn area with some 600-800 grit sandpaper and go with it, have it machined and try to slip it in with some shim material to fill the space or can it be spray(?) welded and machined to the right size? Anyone of you guys had to deal with this?
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
