Farmall Tractors Discussion Board
Re: IH 350 Gas Utility Needs help, owner is stupid
Posted by RKS on April 25, 1999 at 09:51:57:
In Reply to: IH 350 Gas Utility Needs help, owner is stupid posted by W. Blue on April 25, 1999 at 00:09:00:
1. check the oil level in the tractor 2. put the trans in neutral and see if the tractor will roll freely 3. gently rocking just means don't push it or pull it with another tractor or vehicle, but put it in highest gear and give it a real shove, maybe get a friend to push also, and make sure you can not see the "fan" turn - - then check back.
Post a Followup
: Re: Re: IH 350 Gas Utility Needs help, owner is stupid
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
