Re: 12v kit for 340?
Posted by RustyFarmall on March 08, 2007 at 11:26:53 from (66.43.253.11):
In Reply to: Re: 12v kit for 340? posted by MN Mike on March 08, 2007 at 11:16:51:
I think that would be best. The only kits I could find were for the Hs and Ms. Another hint, if you replace the original ignition coil with a new 12 volt with internal resistor, you can forget that little ceramic resistor block.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
