Re: 350 utility Help
Posted by HAS on March 08, 2007 at 13:55:39 from (68.228.165.223):
In Reply to: 350 utility Help posted by iester on March 08, 2007 at 12:51:05:
Does that engine have wet sleeves? If so, it is likely just a sleeve seal. If it has dry sleeves, then you have a problem. Fixing it could be possible depending on the extent of the crack, or corrosion.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
