Re: 12v kit for 340?
Posted by Nawlens Gator on March 08, 2007 at 14:08:38 from (52.128.30.17):
In Reply to: 12v kit for 340? posted by MN Mike on March 08, 2007 at 06:19:13:
I changed one of my 140's over with a 10 SI. Turned it upside down and mounted the short Alternator mount to the front of the tractor's front generator mount (had to drill out from 1/4" to 3/8"). Used a 2 1/2" long 3/8" bolt. Pulley's lined right up. Had to make a special bracket to get the tighteneing brace to fit. Everything fit right in without modifying the shroud.
Use the 3 wire set up with diode. Works great. Puts out up to 63 amps at 14.5 volts. Also went to electronic ignition and high output coil, both bought from this site. I'm pleased.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
