Re: Gas Starting Diesels
Posted by georgeky on March 10, 2007 at 17:38:41 from (152.163.100.199):
In Reply to: Gas Starting Diesels posted by Glenn FitzGerald on March 10, 2007 at 17:33:15:
Glenn if they are in good shape in proper time with a good clean carb they start fairly well. I have one that starts good down to around 20 degrees. I have heard other folks talk about theirs not starting at 40 degree's. When it gets very cold here I use one of the old gasser's to ekiminate starting problems they start all the time. The deisels are expensive to work on.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
