Re: 1971-444 gas starts cold / dies after about 1/
Posted by Owen Aaland on March 10, 2007 at 19:04:58 from (65.165.246.14):
In Reply to: 1971-444 gas starts cold / dies after about 1/2 hr posted by Farmalfamily on March 10, 2007 at 16:56:40:
The coil on your 444 should be a 6 volt coil. There is no external resistor so it looks like it should be a 12 volt but unless someone has changed the wiring harness that is not the case. The resister is actually the wire that runs between the ignition switch and the I terminal on the solenoid. This wire is a steel stranded wire, not copper. Withn the tractor running there should be about 6 volts at the solenoid terminal. The only IH tractors I have seen that use a 12 volt coil are Cub Cadets and those with electronic ignition instead of points. If the ignition wire goes from the switch to the coil and then to the solenoid you need an external resistor. If the ignition wire goes from the switch to the solenoid and then to the coil there should be a steel wire in the harness between the switch and the solenoid and no external resistor is used. One problem with this design is when a strand or two breaks the wire can get hot enough at the break to damage the harness. Almost burned up my 2444 when this happened. IH used the same type of wire for the resistor for the alternator on motor trucks when they switched from 10DN to 10SI alternators.
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
