Re: F12 starting problem
Posted by El Toro on March 11, 2007 at 13:07:24 from (152.163.100.199):
In Reply to: F12 starting problem posted by Roger2021 on March 11, 2007 at 11:23:18:
I think you need to do as Jim suggested. Check that coil for a hot blue spark. Pull the coil wire from the cap after you have the engine running. You may want to use a pair of insulated pliers so you don't get bitten. You should have a hot blue fire from that mag. You may have a weak coil. Those plug wires should be copper wire and the coil wire too. How does the compression feel when hand cranking? You may need to run the the engine so the new rings seat.
Hal
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
