Re: 504 rough running, distributor/timing??
Posted by RUSTY in TX on March 17, 2007 at 08:47:17 from (67.72.98.88):
In Reply to: Re: 504 rough running, distributor/timing?? posted by Roger Mills on March 17, 2007 at 06:45:34:
Thank you for your comments. Fuel system has been completely gone-thru, if anything it may be getting too much fuel, maybe?? Is #1 cy to the left or to the right asyou face the block? sorry for stubid question!! my first time at this. there is a key-way mark on the back-side sprocket of crank shaft pully,...should this be on the very top, when #1 is at tdc??? Agin, thanks for your intrest and comment. RUSTY in TX
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
