Re: 504 Diesel
Posted by Hugh MacKay on March 18, 2007 at 17:32:51 from (209.226.247.52):
In Reply to: Re: 504 Diesel posted by TDK on March 18, 2007 at 13:36:54:
TDK: Having owned a Farmall 504 in the past, I was convinced it was a Farmall he was describing, then he came up with serial number 5858 being a 63 and that indicated Utility.
On the matter of some material missing from archives, I went looking for something I once said, couldn't find it. That was about a month ago. Then I brought up my total posting history since 1999, and found somewhere in the order of 26,000. One year ago, I knew that was very close to 30,000, thus I expected to find somewhere in the order of 34,000 to 35,000 posts. If you look at my history of posting it has been right around 5,000 per year. I had expected I was down a bit in 2006, I'm not quite as keen on this as I once was. I do however suspect there are close to 9,000 posts I made on YT, are missing from the archives.
I've never really raised this before, guess I didn't see it as being very significant. I've never asked anyone else if they noticed the same. When one thinks of the physical working of these forums, I would think it would be total threads missing rather than individual posts. My point is, how do you delete a post without deleteing posts that responded to it. Quite frankly, I don't think I'll loose a lot of sleep over it. I sometimes wonder why Kim archives any of the discussion. Take letter series Farmalls for example, I'll bet every question is in there 100 times minmum.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
