Re: H engine timing
Posted by Tom Windsor on March 25, 2007 at 08:07:28 from (69.40.61.69):
In Reply to: Re: H engine timing posted by georgeky on March 24, 2007 at 21:23:11:
George
Single dot to 2 dots apparently does not work.
My crank gear has a single dot "on" a tooth.
The cam gear has a single dot "between" a tooth and a doble dot "on a tooth".
The distributor gear has a double dot "between" the teeth.
APPARENTLY, TO ME, it seems that single to single and double to double is proper???
TW
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
