Farmall 1566 lights
Posted by Andre Konstantinov on March 26, 2007 at 11:09:33 from (199.125.14.2):
I just bought a 1566. Lights did not work.
Replaced the 20A fuse in the cab, the big fuse under the right side of cab, the bulb for the transmission 'tellite', and the backlight bulb for oil pressure gauge.
What works now: all gauges, transm. 'tellite', cigarette lighter, dome light. Tractor starts well and runs well.
Does not work: any lights (outside) or the instrument panel backlights work. Checked the power to the outside lights with voltmeter - nothing, tried all four positions of the switch.
Replaced the fuse inside the cab and one of the two big fuses under the right side of the cab.
Where do I start looking??? Thanks Andre
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
