Re: md farmall wont switch over whats wrong???
Posted by Ron in Nebr on April 05, 2007 at 23:56:50 from (66.252.113.165):
In Reply to: md farmall wont switch over whats wrong??? posted by md tractor nut on April 05, 2007 at 22:21:15:
Is there fuel at the bleeders on the injectors? With it running on gas, open the throttle just a bit and crack the bleeders open on the injectors- should be fuel there. If not, it's quite possible after sitting for a few years that the plunger in the pump's stuck. The guage I think only shows the pressure from the transfer pump.
If the plunger's stuck, there should be guys on here that can explain in detail how to free it up. Good luck!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
