F12 rebuild
Posted by LKM on April 07, 2007 at 22:40:01 from (4.252.15.115):
I'm rebuilding a 1935 F12 with small seeping crack along the left side water passage of the block. I would like to have this welded instead of using a sealer. I'm wondering if the heat from welding will destroy the seals in the sleeve's as this is a wet sleeve engine. The engine did not smoke and I had intended to put new rings in it while I have it torn down. Also is it possible to pull and put new seals in the existing sleeves as they seem to be in good shape with no appreciable wear or scouring.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
