Re: tail wheel #8 or 16
Posted by Jerry Mandt on April 08, 2007 at 07:49:20 from (216.251.181.51):
In Reply to: tail wheel #8 or 16 posted by 460d on April 08, 2007 at 06:42:46:
You can put washers behind the adjustable collar to take up some of the end play. This won't help if your axle is worn small on the diameter but it will help the end play. I think that they are all somewhat loose that way. Make sure to grease it good and it should be okay.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
