Re: losingcharge
Posted by John T on April 08, 2007 at 07:53:18 from (66.244.90.5):
In Reply to: losingcharge posted by dustin 47 m on April 07, 2007 at 20:38:17:
In regards to whether or not a 6 volt genny will charge an 8 volt battery, the answer I believe is IT DEPENDS::::::::::
1) If the charging system just uses a simple 2 wire Cutout Relay system IT LIKELY CAN
2) If the charging system uses a Voltage Regulator having ONLY a current control relay (in addition to the normal cutout relay) IT LIKELY CAN
3) If the charging system has a Voltage Regulator that has a voltage control relay IT LIKELY WILL NOT UNLESS THE VOLTAGE CONTROL RELAY IS ADJUSTED/TWEAKED
Anyone agree or disagree???
Happy Easter yall
John T
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
