Re: can I interchange the C123 with the C135 eng
Posted by Hugh MacKay on April 09, 2007 at 03:13:29 from (216.208.58.125):
In Reply to: can I interchange the C123 with the C135 engine? posted by Jim Christophel on April 08, 2007 at 19:47:00:
Jim: As Bill mentions, C-135 engines from 330, 340 tractors do not have the crank drilled for the pilot bushing needed in your Super C. You may run across the same with other C-135 engines. If you searce the archives there are a couple of threads where this hole has been drilled in a C-135 crank.
Another item you might look into is water pump and fan. Most C-135 engines have automotive type water pump on the fan hub. Check it out, but I think you can use your SC water pump and fan. Even the 140 and 240 with C-123 engine have the automotive type water pump. I have both type water pumps in my 130 and 140. I think you could also use the automotive pump if you have the right shroud. The difference is not great and as Bill said, a bit of modification will do the trick.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
