IH 404 Hydraulics - Again
Posted by kentv on April 18, 2007 at 07:18:15 from (12.34.32.242):
Hi,
New pump works. Got air out of lines. Final concern. When the remote hydraulic lever is engaged with nothing attached the engine will load and stall if the rpm's aren't up. Same thing happens when the wheels are turned to their extreme of travel. This doesn't happen when the 3 point is lifted all the way.
Thanks.
kent
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
