Please Back Away From the Toolkit
Posted by A. Bohemian on April 20, 2007 at 11:55:16 from (207.170.88.29):
In Reply to: Re: Question on governor spring. posted by unioncreek on April 20, 2007 at 09:48:43:
Low idle: 425 RPM. High idle: 1595 RPM. But read on: Think about it. The tractor was running fine with the governor set up the way it was. Unless you changed the adjustments already, the odds are re-adjusting it won't make any difference. ALL a governor does is help the engine run at a constant speed as load varies. Period. They rarely if ever cause rough running. An exception: if the engine speeds up and slows down and can't seem to make up its mind what speed it wants to run at, the governor is often at fault. This is sometimes called hunting and can often be adjusted out. Try this: with the engine off, grab the throttle rod. Move it through its range. It should be very free with little resistance. Now start the engine. Grab the throttle rod again (watch those belts!) and try to move it. You should notice greatly increased resistance. Increased resistance? Your governor is probably doing its job (unless it is hunting, as described above) and you should probably not mess with the adjustments until you are CERTAIN nothing else is wrong. No resistance? The governor is NOT doing its job. It needs to be fixed before being adjusted. Does the rod move back and forth of its own volition? The governor is hunting. Adjust it per the manual; if it STILL hunts, you may need a rebuild. I don't bet; but if I did, I'd go dollars to donuts that unless you're experiencing hunting, your problem isn't the governor.
Home
| Forums
Today's Featured Article -
A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
