Farmall Tractors Discussion Board
Re: M Governor
Posted by The Red on May 03, 1999 at 02:40:41:
In Reply to: M Governor posted by Tom on May 02, 1999 at 21:49:34:
Tom, I had a similar problem on my 46 H. If the engine stays at idle for the first 3 or 4 notches while you are advancing the throttle lever, then do the following.
Remove the angle plate of the governor shaft housing. You will see the vertical shaft and the horizontal shaft which goes into the carb. You will notice that the vertical shaft sets high in the housing when at idle and is much lower at full throttle. Take that top nut off and remove that tiny cotter pin and take out the big pin that holds the two shafts together. Now rotate the adjusting block that held the big pin one or two turns counter clockwise. Now the throttle butterfly plate will start opening earlier as you pull the throttle lever up.
If that doesn't help, keep a pair of vice grips handy. Currently I am doing that on my 51H since the throttle lever is worn out and won't hold in the jagged teeth.
Post a Followup
: Re: Re: M Governor
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
