Re: Priority valve farmall power steering
Posted by Bob on April 21, 2007 at 22:22:46 from (69.178.229.154):
In Reply to: Re: Priority valve farmall power steering posted by Brian Schmidt on April 21, 2007 at 20:02:53:
"The excess flow will not get anything if the relief setting is not meet."
That's NOT correct.
As soon as the rated "controlled flow" (3 GPM's) to the "CF" port (steering) is met, you will get flow out the "excess flow" port. The "relief valve" will operate ONLY when the pressure at the "CF" port reaches relief valve pressure (1500 PSI). (Steering wheel held against one of the end limits.) The ONLY time the relief valve in the flow divider will operate is... to protect the system when the pressure to the steering circuit exceeds 1500 PSI.
In other words, if the pump is putting out only about 3 GPM's, you will get little or no flow out the "EF" port.
If the pump is putting out 4 GPM's, you will get only about 1 GPM flow out the "EF" port. And so on.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
