Re: The Danger of Hand Cranking
Posted by Janicholson on April 23, 2007 at 17:57:34 from (66.173.50.9):
In Reply to: The Danger of Hand Cranking posted by El Toro on April 23, 2007 at 17:13:53:
An F20 with mounted picker can be very bad. The crank extension to get out of the snout creates a larger radius. The neighbor got a compound fracture of the right arm, and a tooth removed. Bad timing, and poor hand/body location. JimN
  • Pozor! A. Bohemian 07:06:15 04/24/07 (0)
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
