Re: New Idea Loader on IH/Farmall 560 hydraulics
Posted by Hugh MacKay on April 26, 2007 at 19:08:51 from (209.226.247.32):
In Reply to: New Idea Loader on IH/Farmall 560 hydraulics posted by Matt_in_Michigan on April 26, 2007 at 18:50:43:
Matt: It's beem awhile, I presume your Matt from near Mason or Lancing.
The hydraulic cylinder can probably be repaired by most local hydraulic shops. They will also have access to replacment cylinders if needed.
When you say rear hydraulics are you talking Fast Hitch? Is your hitch original as in draft control still working? 560 fast hitches had a second pin 5/8" I think, locks base cylinder hooks to, if the draft control valve has been replaced by a double action valve like the loader valves, it may be switched to single action. There is a stem on top of valve oval ends takes a 5/8 wrench to switch it from single to dual action.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
