Re: clutch replacement
Posted by rustyfarmall on March 20, 2009 at 09:25:44 from (207.199.225.123):
In Reply to: clutch replacement posted by Farrell Godwin on March 20, 2009 at 08:51:24:
There was at least two different styles or brands of clutchs that were installed when the tractor was built. Auburn was one, and Rockford was another one. Your tractor may currently have the Auburn clutch, and the new clutch you bought might be a Rockford. The two do not have identical appearances, but that makes no difference. The only two things that DO matter is the diameter of the clutch, and the diameter and spline count of the inner hub. If both of those are the same on each clutch disc, you're good to go. If those are NOT the same, you need to take it back.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
