Re: 4th gear mph?
Posted by georgeky on May 01, 2007 at 18:37:35 from (205.188.116.138):
In Reply to: 4th gear mph? posted by 1850Turbo on May 01, 2007 at 17:23:02:
Using the TA to slow down will ruin the unit eventually. 4th gear in direct drive is fast enough to do what you want. The TA is just for steady pulls such as plowing or other heavy field work. Without a steady pull while the TA is in low the tractor will overrun the unit and cause damage to the roller and ramp set up on the unit. Used properly the TA will last for years, but if you keep using it to slow tractor down and free wheeling it, it will ruin it. Fourth gear will run between 5 and 7 MPH. Again DO NOT USE TA TO SLOW TRACTOR DOWN.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
