Re: governor on Farmall 350
Posted by georgeky on May 04, 2007 at 11:50:00 from (64.12.117.8):
In Reply to: governor on Farmall 350 posted by Jim Joynt on May 04, 2007 at 10:09:31:
You need to get an IT manual it will give pictures and a step by step procedure for this and most other problems you will encounter with your tractor. One cost around 30 dollars, and it is cheap. The one you need is IH-10, it also covers other models as well. You can order them off this site, look to left and click on manuals. They are available from TSC and other farm supply stores. If I tried to explain it you and me both would be confused, somebody else may be able to. Sorry I wasn't more help, but you do need that manual.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
