Re: 1937 Farmall F-20 Throttle Problems
Posted by Bob Kerr on May 08, 2007 at 04:11:29 from (64.12.117.8):
In Reply to: 1937 Farmall F-20 Throttle Problems posted by Mpuller44 on May 06, 2007 at 16:57:44:
I am not sure if the f-20 has the same gov as the 10-20 does, but I suspect they do. My 10-20 acted up bad when I first got it running and the problem was the Die cast or pot metal "tube" has a spring inside and it was a bit too loose. I just turned the tube a few turns and the spring inside snugged up and it worked perfect after that, and it did govern at low speeds. the Tube is just to the rear of the oil fill cap and lays horizontal. It is about 3 inches long or so.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
