Re: Farmall 756 with German 310 ( few Questions)
Posted by the tractor vet on May 15, 2007 at 04:51:46 from (75.19.126.88):
In Reply to: Farmall 756 with German 310 ( few Questions) posted by migraine on May 14, 2007 at 22:12:37:
Like the rest have said don't sound to bad and set at the 74 ponys means that nobody has tweeded her , the ones i have worked on have all been turned up as most of the guys around here that have them want a bit more for our hills but they work them for the most part and that keeps them cleared out . Getting to know the best way of starting them differs with each of them as no two that i have been around start the same . IF ya get it run it like ya stole if keep good oil and filters on her keep good clean fuel and filters on it and keep the charging system in top shape with good batterys and cables . If the fuel smoke seams heavy to you have them check the timing on the pump myself if i have more smoke then i think it should have i put a couple degrees more advance and this helps clear it up .
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
