Re: CNKS Can you help with axle seal replacement o
Posted by BF8690 on May 24, 2007 at 09:32:17 from (138.163.0.38):
In Reply to: CNKS Can you help with axle seal replacement on 46 posted by Butch WI on May 24, 2007 at 08:09:55:
I'm not sure about the 460 but the M and 560 I have replaced the axel seals on. There should be a cap on the end of the axel housing. Remove that and remove/replace the seal that is contained in the housing. The hardest part is removing the wheels.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
