Re: 2 way hydraulics
Posted by Wild Bill on May 31, 2007 at 13:30:24 from (63.147.9.42):
In Reply to: Re: 2 way hydraulics posted by Pat-CT on May 31, 2007 at 13:21:43:
you will need a two way open center valve (like for a log splitter) for each purpose. Don't mess around trying to find an original IH two way valve, they are out there but way to expensive.
You can get a double spool and run both with it. Just make sure it is two way open center.
tap any of the ports on the belly pump, pipe it to the valve, then plump the return back to the belly pump resevoir, either into the fill pipe, or drill out your drain plug, tap to a larger size and plumb it in there.
Happy tractoring and be careful!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
