Re: SH govornor questions...
Posted by Bob M on June 01, 2007 at 12:42:04 from (151.190.254.108):
In Reply to: SH govornor questions... posted by Matthew(Mich) on June 01, 2007 at 11:02:17:
When I first got it my SH had exactly the same problem.
Fix is to adjust (shorten) the throttle shaft bellcrank under the vent tube cover.
Remove the cotter pin and pivot pin, then loosen the locknut and give the bellcrank a turn or two clockwise on the connecting rod. Then put the pivot pin back in and run the engine - it may take two or three to find the correct adjustment so it idles down correctly. Finally reinstall the cotter pin and gently tighten the locknut.
Tip: Be careful to not drop the cotter pin or bellcrank pivot pin down the riser tube!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
