Re: 400 carb Fuel Pump
Posted by the tractor vet on June 04, 2007 at 21:01:40 from (75.19.120.54):
In Reply to: Re: 400 carb Fuel Pump posted by Steve Weathers on June 04, 2007 at 20:49:04:
Nope . as the hole in the needel and seat is what is the determining factor here Plus the hole from the tank into the sediment bowl. You are only feeding nomore then 281 cubic inch engine with a signal barrel updraft carb not a big holley 4 bbl.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
