ih 350u clutch adj (again)
Posted by lester350u on June 05, 2007 at 18:42:46 from (64.12.117.8):
Ok, after looking at it again through the inspection hole with all linkage removed here is what I come up with.I turned the clutch release lever until t\o bearing was as far back as it would go away from the pressure plate.Now there is approximent 3eights of a inch between t\o and fingers I know this is not what I want for final adj sooooo just bear with me.I started tractor engine still approximent 3eights between the two at idle. BUT when throttle is advanced fingers advance toward t\o bearing that much causeing t\o bearing to spin.Could the finger adj not be correct,Should i try to adjust them tighter? It was a new replacement...gota do something thanks tractor vet and all.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
