Re: 1066, shifting issues again and now not starting
Posted by the tractor vet on June 14, 2007 at 07:33:50 from (75.19.125.193):
In Reply to: 1066, shifting issues again and now not starting posted by Tim_in_IA on June 14, 2007 at 06:35:03:
Like Rusty said the shifter need some work along with some clutch and dump valve adjustment as this is one point that does not see the maintance that it should . As for your starting problems here a 1066 is a 12 volt system , now some one may have at one time added 2 twelve volt batterys when it should have two 6's . When one wants to jump start a 1066 pull the left battery cover and hook the pos. lead to the ft. post of the left battery and put the neg. lead to a good ground on the chassie , myself i use the head of the frame bolt . Also check your clutch safty switch it is under the floor plate on the left side and has linkage that hooks to the clutch pedal linkage.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
