Re: Wiring Question On Dash For 400
Posted by John T on June 17, 2007 at 19:23:28 from (66.244.83.147):
In Reply to: Wiring Question On Dash For 400 posted by Big Country on June 17, 2007 at 19:09:10:
There should be ONLY ONE WIRE on the SUPPLY terminal of the ammeter, thats the one wired to the starter switch (BAT input terminal NOT starter side) where the big battery cable is down from the hot ungrounded battery post......
The ammeters other LOAD terminal wires to the BAT terminal on a Voltage Regulator or the main output stud on an Alternator PLUSSSSSSS feeds hot battery voltage to all loads such as lights and ignition.
Put the alternator or genny output on the LOAD terminal of the ammeter, the same terminal that is wired to the lights or ignition switches to supply them with hot voltage.
If you turn the ignition or lights on tractor not running, the ammeter should swing to - discgharge and then once started if shes charging it will swing over to + charge. If it does the opposite, its wired backwards so simply reverse its leads.
On a neg ground tractor the ignition coils lil - terminal is the one that wires to the distributor while on a Pos ground it would be its + terminal.
John T
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
