Farmall Tractors Discussion Board
Re: 806 PTO will not engage
Posted by Milan H. Dilworth on May 23, 1999 at 22:52:09 from (209.161.38.166):
In Reply to: 806 PTO will not engage posted by david on May 20, 1999 at 07:13:14:
You can easily determine if the small pin in the control value is broken, by taking the plug out below the valve and see if the bottom spring and rod come out, or take out the upper seal base plug and see if you can pull the upper valve on out. I'd strongly suggest installing a piece of wire from an old choke cable in place of the small pin. In 20+ years I've never had the problem repeat itself. The wire is strong and not too brittle like the pin. First put the wire in a shop vise and hit it with a small hammer to bend a 90 deg in the end. Then put the wire in place and snip it off 1/8" ext. Use your hammer and bend the 2nd 90 deg. Then take it to a grinder and smooth up the ends to prevent any over extension.
Post a Followup
: Re: Re: 806 PTO will not engage
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
