Posted by El Toro on March 23, 2009 at 11:18:43 from (64.12.116.73):
In Reply to: Sleeves and Rings posted by Bud W on March 23, 2009 at 10:35:46:
If you're going to tear the engine down I would install a new sleeve kit, bearings and have the head redone. You should have the crankshaft measure for wear at your local auto machine shop to see if it needs to be ground undersize. Get your new bearings from them. You need to clean that area of the block where the sleeve seals are installed of any rust or dirt. If the block is sludged you probably should have it dipped and all the oil passages cleaned. Good time to check the clutch disc too for wear and have it recovered. You don't want to have a problem later and need to pull it apart again. Hal
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
